Salta al contenuto principale
Retro-Bit Retro Duo Cartridge Doors Replacement
Cosa ti serve
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: passo 1, immagine 1 di 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: passo 1, immagine 2 di 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: passo 1, immagine 3 di 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 2, immagine 1 di 3 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 2, immagine 2 di 3 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 2, immagine 3 di 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 3, immagine 1 di 3 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 3, immagine 2 di 3 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 3, immagine 3 di 3
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 4, immagine 1 di 2 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 4, immagine 2 di 2
    • Carefully lift the cartridge door case and set aside.
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: passo 5, immagine 1 di 2 Retro-Bit Retro Duo Cartridge Doors Replacement: passo 5, immagine 2 di 2
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
Conclusione
Truong Vo
Membro da: 09/25/17
320 Reputazione
3 Guide realizzate
USF Tampa, Team S4-G4, Eyestone Fall 2017 Membro di USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 570
