Salta al contenuto principale
Retina MacBook 2017 Lower Case Assembly Replacement
Cosa ti serve
  1. Retina MacBook 2017 Lower Case Assembly Replacement, Disable Auto Boot: passo 1, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement, Disable Auto Boot: passo 1, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement, Disable Auto Boot: passo 1, immagine 3 di 3
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. Retina MacBook 2017 Lower Case Assembly Replacement, Unfasten the lower case: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    Compra
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. Retina MacBook 2017 Lower Case Assembly Replacement: passo 3, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 3, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 3, immagine 3 di 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
  4. Retina MacBook 2017 Lower Case Assembly Replacement: passo 4, immagine 1 di 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
  5. Retina MacBook 2017 Lower Case Assembly Replacement: passo 5, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 5, immagine 2 di 2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
  6. Retina MacBook 2017 Lower Case Assembly Replacement: passo 6, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 6, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 6, immagine 3 di 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
  7. Retina MacBook 2017 Lower Case Assembly Replacement: passo 7, immagine 1 di 1
    • Close the MacBook and carefully flip it upside-down.
  8. Retina MacBook 2017 Lower Case Assembly Replacement: passo 8, immagine 1 di 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
  9. Retina MacBook 2017 Lower Case Assembly Replacement: passo 9, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 9, immagine 2 di 2
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
  10. Retina MacBook 2017 Lower Case Assembly Replacement: passo 10, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 10, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 10, immagine 3 di 3
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
  11. Retina MacBook 2017 Lower Case Assembly Replacement: passo 11, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 11, immagine 2 di 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
  12. Retina MacBook 2017 Lower Case Assembly Replacement: passo 12, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 12, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 12, immagine 3 di 3
    • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
    • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
  13. Retina MacBook 2017 Lower Case Assembly Replacement: passo 13, immagine 1 di 1
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
  14. Retina MacBook 2017 Lower Case Assembly Replacement: passo 14, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 14, immagine 2 di 2
    Battery Blocker
    $3.99
    Compra
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
  15. Retina MacBook 2017 Lower Case Assembly Replacement, USB-C and Audio Jack Disconnect: passo 15, immagine 1 di 1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Phillips #00 screw
    • Some variations of this model may use a Tri-point Y00 screw.
    • 3.5 mm T5 Torx screw
  16. Retina MacBook 2017 Lower Case Assembly Replacement: passo 16, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 16, immagine 2 di 2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
  17. Retina MacBook 2017 Lower Case Assembly Replacement: passo 17, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 17, immagine 2 di 2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
  18. Retina MacBook 2017 Lower Case Assembly Replacement: passo 18, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 18, immagine 2 di 2
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so the white stripe faces you. Insert the cable until the white line disappears under the socket.
    • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
  19. Retina MacBook 2017 Lower Case Assembly Replacement, Lower Case Assembly Removal: passo 19, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement, Lower Case Assembly Removal: passo 19, immagine 2 di 2
    • Use tweezers to peel back the tape covering the display cable connector.
  20. Retina MacBook 2017 Lower Case Assembly Replacement: passo 20, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 20, immagine 2 di 2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
  21. Retina MacBook 2017 Lower Case Assembly Replacement: passo 21, immagine 1 di 1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
  22. Retina MacBook 2017 Lower Case Assembly Replacement: passo 22, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 22, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 22, immagine 3 di 3
    iOpener
    $12.99
    Compra
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
  23. Retina MacBook 2017 Lower Case Assembly Replacement: passo 23, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 23, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 23, immagine 3 di 3
    • Hold the retaining flap open.
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap. Keep it closed throughout your repair.
    • During reassembly, keep the flap closed while you insert the display cable. Remember to orient the cable so its gold contacts face down, making sure not to crimp or fold it—it'll click into place when it's connected.
  24. Retina MacBook 2017 Lower Case Assembly Replacement: passo 24, immagine 1 di 1
    • Separate the upper case assembly from the lower case assembly.
  25. Retina MacBook 2017 Lower Case Assembly Replacement, Logic Board: passo 25, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement, Logic Board: passo 25, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement, Logic Board: passo 25, immagine 3 di 3
    • Use tweezers to peel up the tape covering the two ZIF connectors—one for the right speaker cable, and one for the audio jack board cable.
  26. Retina MacBook 2017 Lower Case Assembly Replacement: passo 26, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 26, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 26, immagine 3 di 3
    • Use the point of a spudger to flip up both ZIF connector retaining flaps.
  27. Retina MacBook 2017 Lower Case Assembly Replacement: passo 27, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 27, immagine 2 di 2
    • Carefully pull straight back on the two pieces of tape you just peeled up to disconnect the two ribbon cables.
  28. Retina MacBook 2017 Lower Case Assembly Replacement: passo 28, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 28, immagine 2 di 2
    • Use the point of a spudger to peel up the foam pad covering the two antenna connectors.
  29. Retina MacBook 2017 Lower Case Assembly Replacement: passo 29, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 29, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 29, immagine 3 di 3
    • Insert one arm of your angled tweezers under the metal neck of the first antenna connector and pry up to disconnect it.
    • The antenna connectors and sockets are extremely fragile. Be very careful to lift only on the connector, and not on the socket itself. Do not lift under the cable, or put any unnecessary strain on it.
  30. Retina MacBook 2017 Lower Case Assembly Replacement: passo 30, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 30, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 30, immagine 3 di 3
    • Pry up the second antenna connector to disconnect it.
  31. Retina MacBook 2017 Lower Case Assembly Replacement: passo 31, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 31, immagine 2 di 2
    • Use a spudger to disconnect the left speaker cable connector by prying it straight up from the logic board.
  32. Retina MacBook 2017 Lower Case Assembly Replacement: passo 32, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 32, immagine 2 di 2
    • Use a spudger to flip up the retaining flap on the trackpad cable ZIF connector.
  33. Retina MacBook 2017 Lower Case Assembly Replacement: passo 33, immagine 1 di 2 Retina MacBook 2017 Lower Case Assembly Replacement: passo 33, immagine 2 di 2
    • Disconnect the trackpad cable from the logic board by gently pulling it straight out of its connector.
    • During reassembly, check that your ZIF connector flaps are flipped up before reinserting their cables.
  34. Retina MacBook 2017 Lower Case Assembly Replacement: passo 34, immagine 1 di 1
    • Remove the single 3.5 mm T5 Torx screw securing the logic board to the lower case.
  35. Retina MacBook 2017 Lower Case Assembly Replacement: passo 35, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 35, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 35, immagine 3 di 3
    • Flip up the front edge of the logic board.
    • Handle the logic board only by its edges.
    • Lift and detach the EMI tape securing the logic board to the lower case.
    • If the tape feels stuck, heat it with a hair dryer or iOpener to soften the adhesive.
    • Reattach the tape securely during reassembly.
  36. Retina MacBook 2017 Lower Case Assembly Replacement: passo 36, immagine 1 di 1
    • Remove the logic board.
  37. Retina MacBook 2017 Lower Case Assembly Replacement, Right Speaker: passo 37, immagine 1 di 1
    • Using tweezers, remove the foam pad covering the screw on the left side of the right speaker.
    • If you pull on the foam portion, it will tear. Try to get your tweezers under the adhesive pad holding the foam to the top of the screw.
  38. Retina MacBook 2017 Lower Case Assembly Replacement: passo 38, immagine 1 di 1
    • Remove the two 4.1 mm T3 Torx screws securing the right speaker.
  39. Retina MacBook 2017 Lower Case Assembly Replacement: passo 39, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 39, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 39, immagine 3 di 3
    • Using tweezers, carefully peel up the tape securing the right antenna cable to the lower case.
  40. Retina MacBook 2017 Lower Case Assembly Replacement: passo 40, immagine 1 di 1
    • Prepare an iOpener and heat the lower case directly beneath the right speaker for 1-2 minutes, in order to soften up the adhesive securing the speaker.
  41. Retina MacBook 2017 Lower Case Assembly Replacement: passo 41, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 41, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 41, immagine 3 di 3
    • Use a plastic opening tool to pry under the top edge of the right speaker, and separate it from the lower case.
  42. Retina MacBook 2017 Lower Case Assembly Replacement: passo 42, immagine 1 di 1
    • Remove the right speaker.
  43. Retina MacBook 2017 Lower Case Assembly Replacement, Left Speaker: passo 43, immagine 1 di 1
    • Using tweezers, remove the foam pad covering the screw on the right side of the left speaker.
  44. Retina MacBook 2017 Lower Case Assembly Replacement: passo 44, immagine 1 di 1
    • Remove the two 4.1 mm T3 Torx screws securing the left speaker to the lower case.
  45. Retina MacBook 2017 Lower Case Assembly Replacement: passo 45, immagine 1 di 1
    • Prepare an iOpener and heat the lower case directly beneath the left speaker, in order to soften up the adhesive securing the speaker.
  46. Retina MacBook 2017 Lower Case Assembly Replacement: passo 46, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 46, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement: passo 46, immagine 3 di 3
    • Use a plastic opening tool to pry under the top edge of the left speaker, and separate it from the lower case.
  47. Retina MacBook 2017 Lower Case Assembly Replacement: passo 47, immagine 1 di 1
    • Remove the left speaker assembly.
  48. Retina MacBook 2017 Lower Case Assembly Replacement, Lower Case Assembly: passo 48, immagine 1 di 3 Retina MacBook 2017 Lower Case Assembly Replacement, Lower Case Assembly: passo 48, immagine 2 di 3 Retina MacBook 2017 Lower Case Assembly Replacement, Lower Case Assembly: passo 48, immagine 3 di 3
    • Carefully peel away the audio board ribbon cable from the adhesive securing it to the lower case.
    • Take care not to damage the cable. If the adhesive offers a lot of resistance, first soften the adhesive by heating the lower case directly beneath with an iOpener, and try again.
    • Remove the audio board ribbon cable.
  49. Retina MacBook 2017 Lower Case Assembly Replacement: passo 49, immagine 1 di 1
    • Lower case assembly remains.
    • The battery is strongly glued into place and is commonly replaced together with the lower case. If you need to replace the battery separately, follow the battery guide. The battery should not be re-used or reinstalled after removal.
Conclusione
Altre 4 persone hanno completato questa guida.
Tobias Isakeit
Membro da: 03/31/14
117.588 Reputazione
188 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 101
Tutti i Tempi: 6,018
