Salta al contenuto principale
Restroom Sink Replacement
Cosa ti serve
  1. Restroom Sink Replacement, Restroom Sink: passo 1, immagine 1 di 3 Restroom Sink Replacement, Restroom Sink: passo 1, immagine 2 di 3 Restroom Sink Replacement, Restroom Sink: passo 1, immagine 3 di 3
    • Turn off the water source beneath the sink.
    • If the sink is a bit old or rusted, make sure to wipe it with wipes and paper towels.
    • Wear Gloves for better grip of knobs and to prevent spills over your hand or arm.
    Chiedi a FixBot
    Aggiungi Commento
  2. Restroom Sink Replacement: passo 2, immagine 1 di 3 Restroom Sink Replacement: passo 2, immagine 2 di 3 Restroom Sink Replacement: passo 2, immagine 3 di 3
    • Turn on the knobs on the sink to confirm the water is off and release the remaining water.
    • Always have a container ready when checking for remaining water to catch in.
    • Once you are finished reassuring, you can move onto step 3.
    Chiedi a FixBot
    Aggiungi Commento
  3. Restroom Sink Replacement: passo 3, immagine 1 di 3 Restroom Sink Replacement: passo 3, immagine 2 di 3 Restroom Sink Replacement: passo 3, immagine 3 di 3
    • Gently loosen the elbow that connects the sink to the pipe leading to the wall with pliers.
    • Use a container to catch any water in the elbow.
    • Don't use too much strength to avoid damage to the wall pipping as you loosen the elbow.
    Chiedi a FixBot
    Aggiungi Commento
  4. Restroom Sink Replacement: passo 4, immagine 1 di 3 Restroom Sink Replacement: passo 4, immagine 2 di 3 Restroom Sink Replacement: passo 4, immagine 3 di 3
    • With a sharp blade, cut along the old silicon to detach the sink from the cabinet.
    • Use blase with caution to avoid injury to self or damage to the sink.
    • Then detach the hoses from below the sink.
    • Beware, water might be in the hoses as you detach them.
    Chiedi a FixBot
    Aggiungi Commento
  5. Restroom Sink Replacement: passo 5, immagine 1 di 3 Restroom Sink Replacement: passo 5, immagine 2 di 3 Restroom Sink Replacement: passo 5, immagine 3 di 3
    • When you are done with steps 1 through 4, remove the old sink and replace it with the new one.
    • If your new sink is a newer model, make sure it has the same length and width with a measuring tape.
    • Beware to avoid damage to the sink or cabinet, if it is placed by force.
    Chiedi a FixBot
    Aggiungi Commento
  6. Restroom Sink Replacement: passo 6, immagine 1 di 3 Restroom Sink Replacement: passo 6, immagine 2 di 3 Restroom Sink Replacement: passo 6, immagine 3 di 3
    • Reconnect the hoses and turn on the water with the knobs under the sink, to make sure it runs smoothly.
    • Apply silicon to seal areas around sink and let it dry.
    • Wait for the silicon to dry before using it.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To conclude, replacing a sink seems like a tedious job. But, any beginner can do it without a plumber's assistance. Therefore, saving lots of money on labor.
Robertcastillo
Membro da: 03/21/23
142 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 6
Ultimi 30 giorni: 45
Tutti i Tempi: 525
