Salta al contenuto principale
Resetting the Clock
  1. Resetting the Clock, Resetting the Clock: passo 1, immagine 1 di 1
    • Locate the buttons named "SET", "SKIP", "VOLUME -", and "VOLUME +", which are situated on the top portion of the Nextplay NP109CR.
  2. Resetting the Clock: passo 2, immagine 1 di 2 Resetting the Clock: passo 2, immagine 2 di 2
    • Press the "SET" button, the first button from the left in the row located behind the pink snooze bar, three (3) times until the clock display is flashing.
  3. Resetting the Clock: passo 3, immagine 1 di 1
    • Press the "SKIP" button with the two triangles next to it pointing to the right to advance the hour.
  4. Resetting the Clock: passo 4, immagine 1 di 1
    • Press the "SKIP" button with the two triangles pointing to the left to retreat the hour.
  5. Resetting the Clock: passo 5, immagine 1 di 1
    • Press the "VOLUME +" button to advance the minutes forward.
  6. Resetting the Clock: passo 6, immagine 1 di 1
    • Press the "VOLUME -" button to decrease the minutes.
Conclusione
Once the desired time has been set, the display will continue flashing for about five (5) seconds. When the clock has stopped flashing the clock has been reset successfully. Setting the clock can be very useful when traveling or when living in an area with frequent power outages.
Jacob Aube
Membro da: 09/24/12
1 Reputazione
1 Guida realizzata
Cal Poly, Team 7-50, Forte Fall 2012 Membro di Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,489
