Salta al contenuto principale
ResMed S9 VPAP Auto Inner and Outer Filters Replacement
Cosa ti serve
  1. ResMed S9 VPAP Auto Inner and Outer Filters Replacement, Inner and Outer Filters: passo 1, immagine 1 di 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement, Inner and Outer Filters: passo 1, immagine 2 di 2
    • Lift up on the lip of the translucent plastic filter cover on the bottom of the device.
    • Peel back the old filter and replace it with the new one.
  2. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 2, immagine 1 di 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 2, immagine 2 di 2
    • To access the internal filter of the ResMed S9 VPAP Auto, flip the device upside down.
    • Use a T3 Torx screwdriver to remove the screw in the corner.
    • Each screw in this guide is a 1.2 mm Torx T3.
  3. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 3, immagine 1 di 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 3, immagine 2 di 2
    • Use a spudger to pry off the back panel.
  4. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 4, immagine 1 di 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 4, immagine 2 di 2
    • Use the spudger to pry off the front panel.
    • If you are having difficulty, press the two hooks to open that side of the device.
    • Remove to expose the control panel.
  5. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 5, immagine 1 di 1
    • Remove the two screws on the circuit board with a T3 Torx screwdriver.
  6. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 6, immagine 1 di 3 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 6, immagine 2 di 3 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Remove the plug connecting the red, orange, and black wires to the circuit board.
    • The plug in the top right corner is accessed through the bottom of the device.
    • Flip the circuit board upside down and use the tweezers to squeeze the plastic release underneath the remaining plug.
    • The circuit board will then lift right off, exposing the interior of the machine.
  7. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 7, immagine 1 di 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 7, immagine 2 di 2
    • Remove the five screws from the frame with a T3 Torx screwdriver.
    • Lift off the plastic frame to expose the filter housing.
  8. ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 8, immagine 1 di 2 ResMed S9 VPAP Auto Inner and Outer Filters Replacement: passo 8, immagine 2 di 2
    • Remove the silicone and the blower to expose the filters.
    • Remove and replace the foam filters.
Conclusione
Un commento
where can I purchase the foam filters?
Francis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 19
Tutti i Tempi: 888
