Introduzione
I am teaching you how to repair the hard drive of the HP 15-bs015dx laptop. You can consult a more complete disassembly guide on my profile
Cosa ti serve
Put the laptop facing down
Move the left battery safe lock to the right
Slide the right battery safe lock to the left
This lock is harder than the previous, with this the battery should pop-up.
Use a straw to take off just enough of the rubber feet of the 4 corners
Use a Phillips screwdriver 0
Replace each rubber foot in place after removing the screws
You will have a total of 10 screws
It will go out easily with or without a straw
You can check the model number
Flip the laptop and open it
Use a plastic tool or a straw to separate the pieces of the chassis
Flip the laptop and separate the inferior cover of the chassis
Hard Drive 2.5" SATA
2 RAM memory slots type DDR4 SO-DIMM
CPU Intel 7th generation
Active heat sink (fan)
Wireless card
Watch battery, 3V. CR2030
3 screws
Use a Phillips 0 screwdriver
Remove the frame
Tilt the hard drive up
Disconnect the hard drive from its SATA port
The hard drive is 7mm high. 1TB capacity.
For re-assembly of your device, follow these instructions in reverse.
Altre 9 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
6 Commenti
Disculpa, yo tengo esta laptop, mi hard drive hdd se estropeó y quisiera cambiarlo por un ssd, sin embargo no se que tipo de ssd necesito, si eres tan amable de aclararme mi duda, se agradecería.
Saludos. Te toca comprar un SSD tipo SATA. Puedes revisar mi perfil, ahí tengo mis RRSS y me puede contactar.
Great but how do you get the software to reinstall on the new hard drive?
That would require a whole new guide. I have some of those on my YouTube channel, link in my ifixit profile.
Bottom line: A flash drive with a Windows installer on it.
