Introduzione
This guide will show you how to remove and replace the hard drive in an IBM ThinkPad 560z.
Cosa ti serve
Remove the 7 mm Phillips #0 screws.
Remove the 10 mm Phillips #0 screws.
Remove the 14 mm Phillips #0 screw.
On the back of the computer, use a Flathead screwdriver to remove this lone screw.
Altre 2 persone hanno completato questa guida.
Un commento
You don't have to go to this length to remove the hard drive on a 560Z. Only do steps 0 (remove battery), 9 (remove screw) and 10 (remove cover). Then simply grab the blue tab of the hard drive caddy and pull the drive out of the bay. Complete directions on maintenance of the IBM Thinkpad 560Z can be found here:
http://www.thinkpads.com/support/hmm/hmm...
The Hardware Maintenance Manual has all of the information you need to take a 560Z apart and put it back together.
The procedure outlined here is similar to what the 560, 560E and 560X systems required; the 560Z is totally different when removing the hard drive.
