Salta al contenuto principale
Replacing flash memory to a cisco 837 series router
Cosa ti serve
  1. Replacing flash memory to a cisco 837 series router, Flash memory: passo 1, immagine 1 di 1
    • CISCO 837 Router
    • CISCO 877 Router
Conclusione
CONCLUSION
Replacing flash need a tftp server available;
Replacing flash need a copy of the IOS image;
Replacing flash need the usage of ROMMON; be sure that this is possible;
Removing the flash card and inserting it back is like replacing with a new one (IOS image will be gone, so don’t play it with ease);
use the first ethernet port to connect with the tftp server, although all 4 switch ports will work presumably because all being in the same first VLAN.
To reassemble your device, follow these instructions in reverse order and that's all.
Eneider Colina
Membro da: 09/20/13
2.370 Reputazione
9 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,478
