Replacing a Leg from a Wooden Folding Table with Metal Legs
Introduzione
This guide will walk through the process of identifying possible sources from instability in a Wooden Folding Table with Metal Legs, and how to replace the damaged leg. The table leg is an essential part as it allows the table to stand up. Some reasons as to why a replacement would be necessary is the leg is wobbly and/or the groves for which the pins enter in order for the table leg to become secured are worn out. Not everyone has the finances to go and buy another table, especially if multiple of the same kind of table is required. Following this guide will permit extension of the table’s service life.
Use a Phillips #2 screwdriver to remove all ten 12mm screws from the table leg.
Make sure when removing the final screws that you hold the metal leg piece up, so that after the removal of the final screws, the leg doesn’t fall off the table.
Pro Tip: Apply constant pressure to the screwdriver to gently remove the screws and avoid stripping the screw head.
After all the screws are secured in their original position, verify that the bottom of the table has been properly installed, and stand it up to ensure stability and safety for future use.
