Salta al contenuto principale
Replacing a Broken/Cracked Window Blind Slat
Cosa ti serve
  1. Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: passo 1, immagine 1 di 2 Replacing a Broken/Cracked Window Blind Slat, Window Blind Slat: passo 1, immagine 2 di 2
    • Adjust the angle of the blinds until every slat is flat or laying horizontally using the blind's wand.
  2. Replacing a Broken/Cracked Window Blind Slat: passo 2, immagine 1 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 2, immagine 2 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 2, immagine 3 di 3
    • Carefully remove the damaged slat by cutting the slant halfway across its width, at the point where it is connected to the rest of the blind, with a pair of 8-inch 'Westcott' scissors.
    • Remove the damaged slat from the blind after it has been cut on both sides.
  3. Replacing a Broken/Cracked Window Blind Slat: passo 3, immagine 1 di 1
    • Choose an un-cracked slat from a part of the blind that is unaffected during normal use - preferably from the very bottom of the blind.
  4. Replacing a Broken/Cracked Window Blind Slat: passo 4, immagine 1 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 4, immagine 2 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 4, immagine 3 di 3
    • Carefully cut the selected slat halfway across its width, at its two connected points.
    • Carefully remove the replacement slat from its old position, making sure to not extend the cut you made past halfway of the slats width.
  5. Replacing a Broken/Cracked Window Blind Slat: passo 5, immagine 1 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 5, immagine 2 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 5, immagine 3 di 3
    • Carefully place the replacement slat it into its new position.
    • Connect the replacement slat to the support strings at the points where the cuts were made.
  6. Replacing a Broken/Cracked Window Blind Slat: passo 6, immagine 1 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 6, immagine 2 di 3 Replacing a Broken/Cracked Window Blind Slat: passo 6, immagine 3 di 3
    • Tear off a small piece of invisible tape from the roll of tape and carefully place it over the cuts that were made on the replacement slat.
    • Apply tape over the top and bottom of the cuts, on both sides of the replacement slat.
  7. Replacing a Broken/Cracked Window Blind Slat: passo 7, immagine 1 di 2 Replacing a Broken/Cracked Window Blind Slat: passo 7, immagine 2 di 2
    • Twist the wand of the window blind to test it after applying the tape to both sides of the replacement slat.
    • If the replacement slat stays in its new position then congratulations, you have completed the fix!
Conclusione
Moses Matovu
Membro da: 03/22/21
145 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 116
Tutti i Tempi: 4,856
