Salta al contenuto principale
Replacing Sonos Play 1 Power and Volume switch board.
Cosa ti serve
  1. Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: passo 1, immagine 1 di 2 Replacing Sonos Play 1 Power and Volume switch board., Exterior Screen: passo 1, immagine 2 di 2
    • Remove the rubber footing from the bottom of the device. Pry it up from one end using one of the plastic opening tools.
    • Once you pry open one end, use precision tweezers to remove rubber footing.
  2. Replacing Sonos Play 1 Power and Volume switch board.: passo 2, immagine 1 di 2 Replacing Sonos Play 1 Power and Volume switch board.: passo 2, immagine 2 di 2
    • Using a metal spudger, pry open a corner of the adhesive tape.
    • Use precision tweezers to remove the adhesive tape.
  3. Replacing Sonos Play 1 Power and Volume switch board.: passo 3, immagine 1 di 2 Replacing Sonos Play 1 Power and Volume switch board.: passo 3, immagine 2 di 2
    • Remove the four 10 mm Torx security #10 screws that hold the base together.
    • Remove the base by lifting it vertically away from the bulk of the device.
  4. Replacing Sonos Play 1 Power and Volume switch board.: passo 4, immagine 1 di 2 Replacing Sonos Play 1 Power and Volume switch board.: passo 4, immagine 2 di 2
    • Remove the 10 mm Torx security #10 screw that holds down the exterior screen.
    • Using precision tweezers, remove the metal bracket.
  5. Replacing Sonos Play 1 Power and Volume switch board.: passo 5, immagine 1 di 1
    • Remove the exterior screen by lifting it away from the bulk of the device.
  6. Replacing Sonos Play 1 Power and Volume switch board., Sonos Play 1 Top Cover Disassembly: passo 6, immagine 1 di 1
    • Remove the four 9 mm Torx Security #9 head screws. There are two on each side.
  7. Replacing Sonos Play 1 Power and Volume switch board.: passo 7, immagine 1 di 3 Replacing Sonos Play 1 Power and Volume switch board.: passo 7, immagine 2 di 3 Replacing Sonos Play 1 Power and Volume switch board.: passo 7, immagine 3 di 3
    • Using a plastic opening tool, pry open the top cap containing the power and volume button.
    • Vertically remove the top cap.
    • Be sure to not jerk the top cap when removing , as to not damage the cable linking the switchboard to the motherboard.
  8. Replacing Sonos Play 1 Power and Volume switch board.: passo 8, immagine 1 di 2 Replacing Sonos Play 1 Power and Volume switch board.: passo 8, immagine 2 di 2
    • Using a plastic opening tool, pry open the circuit flap.
    • Once flap is loosened, use your hand to remove the circuit wire.
  9. Replacing Sonos Play 1 Power and Volume switch board., Power and Volume Switch Board: passo 9, immagine 1 di 1
    • Using a screwdriver with a Torx T6 bit, remove the four highlighted 7mm screws.
    • Using you fingers remove the protective plastic plate covering the device.
  10. Replacing Sonos Play 1 Power and Volume switch board.: passo 10, immagine 1 di 2 Replacing Sonos Play 1 Power and Volume switch board.: passo 10, immagine 2 di 2
    • Using your fingers remove the plastic cover plate securing the switchboard.
    • Using your fingers, remove the power/volume switch board.
Conclusione
Altre 4 persone hanno completato questa guida.
Patty
Membro da: 09/01/15
450 Reputazione
1 Guida realizzata
USF Tampa, Team 8-4, Eyestone Fall 2015 Membro di USF Tampa, Team 8-4, Eyestone Fall 2015
USFT-EYESTONE-F15S8G4
4 Membri
16 Guide realizzate
9 Commenti
Where can I get the replacement power button?
Teresa Rosales - Replica
I would like to know as well
hung pham - Replica
Dear Patty
Where can I buy the switchboard?
Thanks in advance. :-)
/Kenneth
Kenneth - Replica
Same quesion here from DK
Lars Jürgensen - Replica
where can i find board
craigmdyer - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 62
Tutti i Tempi: 8,675
