Salta al contenuto principale
Replacing Samsung Galaxy S4 SIM Card
Cosa ti serve
  1. Replacing Samsung Galaxy S4 SIM Card, Rear Case: passo 1, immagine 1 di 2 Replacing Samsung Galaxy S4 SIM Card, Rear Case: passo 1, immagine 2 di 2
    • Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
  2. Replacing Samsung Galaxy S4 SIM Card: passo 2, immagine 1 di 3 Replacing Samsung Galaxy S4 SIM Card: passo 2, immagine 2 di 3 Replacing Samsung Galaxy S4 SIM Card: passo 2, immagine 3 di 3
    • Lift the rear case by the corner nearest the divot and remove it from the phone.
  3. Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, immagine 1 di 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, immagine 2 di 3 Replacing Samsung Galaxy S4 SIM Card, MicroSD Card: passo 3, immagine 3 di 3
    • Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Remove the microSD card.
    • For reassembly, push the microSD card into the slot until it clicks in place.
  4. Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, immagine 1 di 3 Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, immagine 2 di 3 Replacing Samsung Galaxy S4 SIM Card, Battery: passo 4, immagine 3 di 3
    • Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
    • Remove the battery from your phone.
  5. Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, immagine 1 di 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, immagine 2 di 3 Replacing Samsung Galaxy S4 SIM Card, SIM Card: passo 5, immagine 3 di 3
    • Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
    • Remove the SIM card.
    • During reassembly, push the SIM card into the slot until it clicks in place.
Conclusione
Altre 78 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.780 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
3 Commenti
Can you take one sim card slot out one galaxy s4 and put it in another or do u have to buy a new one
marius williams - Replica
Somethings wrong with sim card start shut out since July 5 evening and today July 6 three times
humeston23 - Replica
Removing sim card tray?
G M Chadwick - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 70
Ultimi 30 Giorni: 308
Tutti i Tempi: 245,772
