Salta al contenuto principale
Introduzione
I will be providing clear and easy steps on how to replace your Battery/Memory Card Cover Lock on your digital camera with out having to buy another one.
Ricambi
Nessuna parte specificata.
  1. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock, Locate the Battery/Memory Card Cover Lock.: passo 1, immagine 1 di 1
    • Turn the camera so the bottom is facing upwards.
  2. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 2, immagine 1 di 1
    • First pull open latch to expose two screws covering lock.
    • Use your Phillips #00 screwdriver and unscrew both screws.
  3. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 3, immagine 1 di 1
    • Remove the small black lock.
  4. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 4, immagine 1 di 1
    • Turn latch over.
    • There will be one screw visible holding down the cover.
    • Unscrew single screw with your Phillips #00 screwdriver.
  5. Replacing Olympus Stylus Tough-6000 Battery/Memory Card Cover Lock: passo 5, immagine 1 di 1
    • Use your tweezers for this step.
    • After unscrewing the screw you will see a single spring.
    • Make sure spring is in place to be able to close lock properly.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 692
