Salta al contenuto principale
Replacing Nokia Classic 2600c-2b Faceplate
Cosa ti serve
  1. Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: passo 1, immagine 1 di 2 Replacing Nokia Classic 2600c-2b Faceplate, Faceplate: passo 1, immagine 2 di 2
    • Press down on the button located at the bottom of the phone, using the center ridge as a guide.
    • Pull the phone apart from the bottom, keeping the button pressed down.
    • CAUTION! The plastic opening tool may be used to gain leverage. Some force is required to open.
  2. Replacing Nokia Classic 2600c-2b Faceplate: passo 2, immagine 1 di 1
    • Remove the back cover to expose the battery.
  3. Replacing Nokia Classic 2600c-2b Faceplate: passo 3, immagine 1 di 2 Replacing Nokia Classic 2600c-2b Faceplate: passo 3, immagine 2 di 2
    • Place a finger or plastic opening tool in the gap between the battery and the phone.
    • Gently lift the battery out.
  4. Replacing Nokia Classic 2600c-2b Faceplate: passo 4, immagine 1 di 2 Replacing Nokia Classic 2600c-2b Faceplate: passo 4, immagine 2 di 2
    • Locate the plastic latches on the left and right sides of the phone.
    • Insert the plastic opening tool or a fingernail into each latch and pry them open individually.
    • CAUTION! Some force is required.
  5. Replacing Nokia Classic 2600c-2b Faceplate: passo 5, immagine 1 di 1
    • Remove the faceplate with the number pad attached.
  6. Replacing Nokia Classic 2600c-2b Faceplate: passo 6, immagine 1 di 1
    • Turn the faceplate so the number pad faces downward.
    • Lift the number pad out of the faceplate.
    • Apply new faceplate.
    • Follow the instructions in reverse order to reassemble the phone.
Conclusione
Ian VanZandt
Membro da: 02/14/12
654 Reputazione
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 397
