Salta al contenuto principale
Replacing Motorola V60i Logic Board
Cosa ti serve
  1. Replacing Motorola V60i Logic Board, Battery: passo 1, immagine 1 di 2 Replacing Motorola V60i Logic Board, Battery: passo 1, immagine 2 di 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Replacing Motorola V60i Logic Board: passo 2, immagine 1 di 2 Replacing Motorola V60i Logic Board: passo 2, immagine 2 di 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Replacing Motorola V60i Logic Board, Back Plate: passo 3, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Replacing Motorola V60i Logic Board: passo 4, immagine 1 di 2 Replacing Motorola V60i Logic Board: passo 4, immagine 2 di 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Replacing Motorola V60i Logic Board: passo 5, immagine 1 di 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
  6. Replacing Motorola V60i Logic Board, Motherboard: passo 6, immagine 1 di 1
    • Gently lift logic board from back plate.
  7. Replacing Motorola V60i Logic Board: passo 7, immagine 1 di 2 Replacing Motorola V60i Logic Board: passo 7, immagine 2 di 2
    • Place logic board on front cover.
    • Unsnap orange wire that connects the logic board to keypad sensor to allow the logic board to move freely.
Conclusione
Cal Poly, Team 30-40, Garner Spring 2010 Membro di Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Membri
14 Guide realizzate
Un commento
Quero comprar esse aparelho, alguém tem para vender?
Karison Mesquita - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,169
