Cosa ti serve
Remove the back cover by prying it off with a fine tool (I used a screwdriver).
Remove the sim/mic tray and the 13 screw that hold the intermediate cover to the screen frame.
With a thin tool, pull apart the screen cover, inserting it with care.
Once slightly pulled apart, you can continue separating it, using a nail or the spudger.
Disconnect the flex cable for the bottom screen.
Now that the motherboard has been released from the easily removable components, pick it up lightly by the side of the USB connector
Once you've picked it up, take it by hand and pull it slightly upwards to the left.
Move the remaining pieces from the old frame to the new frame.
- 2 flex cables (on button + speaker connector). Marked with red squares
- 2 rubber bands (main mic + noise-cancelling mic). Marked with lilac circles
- Vibrator. Marked with a red square
front flashlight. Marked with a lilac circle
Handset. Marked with a red square
For ease: metal mesh above the screen flex (green square) and humidity indicator sticker (lilac circle). I've passed them.
Once you have placed all the components into the new frame, proceed with the previous steps in reverse to reassemble the cell phone
Filler image
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
