Salta al contenuto principale
IBM ThinkPad 560z Screen Replacement
Cosa ti serve
  1. IBM ThinkPad 560z Screen Replacement, Battery Removal: passo 1, immagine 1 di 1
    • Slide the battery release latch to the right.
    • Pull out the battery out towards the front of the device.
  2. IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: passo 2, immagine 1 di 2 IBM ThinkPad 560z Screen Replacement, Screw Cover Removal: passo 2, immagine 2 di 2
    • Remove the plastic screw covers, then remove the 3 Phillips screws under them.
  3. IBM ThinkPad 560z Screen Replacement, Screen Bezel Removal: passo 3, immagine 1 di 1
    • Insert the plastic opening tool between the front cover and back cover to pry open the screen case, then carefully pull the bezel off.
  4. IBM ThinkPad 560z Screen Replacement, LCD Removal Preperation: passo 4, immagine 1 di 1
    • Remove the four Phillips head screws.
  5. IBM ThinkPad 560z Screen Replacement, Ribbon Cable Disconnection: passo 5, immagine 1 di 1
    • Using your fingers or an Opening Tool, detach the connector on the right side of the screen.
  6. IBM ThinkPad 560z Screen Replacement, LCD Removal: passo 6, immagine 1 di 2 IBM ThinkPad 560z Screen Replacement, LCD Removal: passo 6, immagine 2 di 2
    • Slowly pull back the screen from the top and disconnect the ribbon cable from the back to completely free the screen from the laptop.
    • The connector is very fragile, so be careful.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 26-27, Regan Spring 2010 Membro di Cal Poly, Team 26-27, Regan Spring 2010
CPSU-REGAN-S10S26G27
3 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 4,952
