Salta al contenuto principale
Replacing Creative Zen X-Fi Motherboard
Cosa ti serve
  1. Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: passo 1, immagine 1 di 3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: passo 1, immagine 2 di 3 Replacing Creative Zen X-Fi Motherboard, Detaching Front Case: passo 1, immagine 3 di 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Motherboard, Rubber Button Cover: passo 2, immagine 1 di 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Motherboard, Button Input Chip Part 1: passo 3, immagine 1 di 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Motherboard, Button Input Chip: passo 4, immagine 1 di 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
  5. Replacing Creative Zen X-Fi Motherboard, Access Midsection Plate: passo 5, immagine 1 di 1
    • Lift open the LCD screen and button input chip to access the entire midsection plate.
  6. Replacing Creative Zen X-Fi Motherboard, Unscrew below Button Chip: passo 6, immagine 1 di 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
  7. Replacing Creative Zen X-Fi Motherboard, Unscrew below LCD Screen: passo 7, immagine 1 di 1
    • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
  8. Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: passo 8, immagine 1 di 2 Replacing Creative Zen X-Fi Motherboard, Pull the Motherboard Out: passo 8, immagine 2 di 2
    • Lift the right edge of the motherboard off the back case.
    • Using two fingers to grip the edge of the board, slide the motherboard out of the case to the right.
Conclusione
USF Tampa, Team 1-1, Remmell Fall 2015 Membro di USF Tampa, Team 1-1, Remmell Fall 2015
USFT-REMMELL-F15S1G1
5 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 20
Tutti i Tempi: 534
