Salta al contenuto principale
Replacing Creative Zen X-Fi Button Input Chip Part 1
Westley Courchene
Westley Courchene e 2 altri collaboratori
Ultimo aggiornamento il 17 giu 2015
2 minuti
Moderato
Necessarie Immagini Migliori
Introduzione
Vai al passo 1
This chip allows the user to input information to the device and to navigate the MP3 player's menus.
Cosa ti serve
Strumenti
  • Spudger
    Spudger
  1. Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: passo 1, immagine 1 di 3 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: passo 1, immagine 2 di 3 Replacing Creative Zen X-Fi Button Input Chip Part 1, Detaching Front Case: passo 1, immagine 3 di 3
    • Using a spudger, wedge the tip between the front and back case to pry them apart.
    • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
  2. Replacing Creative Zen X-Fi Button Input Chip Part 1, Rubber Button Cover: passo 2, immagine 1 di 1
    • The black rubber button pad can be removed by simply picking it up.
  3. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip Part 1: passo 3, immagine 1 di 1
    • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
  4. Replacing Creative Zen X-Fi Button Input Chip Part 1, Button Input Chip: passo 4, immagine 1 di 1
    • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
    • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 376
