Salta al contenuto principale
Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle
Cosa ti serve
  1. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle, Cog and lockring: passo 1, immagine 1 di 1
    • Remove the 9.5mm bolts on the rear wheel with an adjustable wrench. There is a bolt on each side of the wheel.
  2. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 2, immagine 1 di 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 2, immagine 2 di 3 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 2, immagine 3 di 3
    • Loosen the 4mm by 50.8mm chain tension screw with a hex key. There is a screw on each side of the wheel.
  3. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 3, immagine 1 di 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 3, immagine 2 di 2
    • Remove the chain from the rear wheel cog. Remove the rear wheel from the frame of the bike.
  4. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 4, immagine 1 di 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 4, immagine 2 di 2
    • Remove the lockring on the back tire using a lockring wrench. To loosen the lockring twist the wrench clockwise.
  5. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 5, immagine 1 di 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 5, immagine 2 di 2
    • Loosen the cog using a chain whip and adjustable pliers. Rap the chain whip around the cog. Push the chain whip handle down so that the cog twists counterclockwise.
    • It will take a lot of force to loosen the cog.
  6. Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 6, immagine 1 di 2 Replacing Cog and Lockring on the Rear Wheel of a Retrospec Fixed-Gear Bicycle: passo 6, immagine 2 di 2
    • Remove the cog the rest of the way with your hand. Replace with a new cog.
Linea Traguardo
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 70
Tutti i Tempi: 4,046
