Salta al contenuto principale
Replacing Atari Lynx Buttons and D-Pad
Cosa ti serve
  1. Replacing Atari Lynx Buttons and D-Pad, Atari Lynx: passo 1, immagine 1 di 1
    • Before disassembling your Atari Lynx, be sure the device is powered off.
    • Remove any game in the console by opening the right latch and sliding the game to the right.
  2. Replacing Atari Lynx Buttons and D-Pad: passo 2, immagine 1 di 1
    • Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
    • Pinch the rear panel with your fingers and lift away from the Atari.
  3. Replacing Atari Lynx Buttons and D-Pad: passo 3, immagine 1 di 1
    • Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear any wires attached to battery panel.
  4. Replacing Atari Lynx Buttons and D-Pad: passo 4, immagine 1 di 1
    • Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
    • Be sure not to tear the speaker wire while removing the control panel.
  5. Replacing Atari Lynx Buttons and D-Pad, Buttons and D-Pad: passo 5, immagine 1 di 1
    • If you want to replace the buttons other than the D-pad, you can pull them up by pinching the sides with your fingers and lifting away from the front panel of Atari.
  6. Replacing Atari Lynx Buttons and D-Pad: passo 6, immagine 1 di 2 Replacing Atari Lynx Buttons and D-Pad: passo 6, immagine 2 di 2
    • To remove the D-Pad, remove three 10 mm Phillips #0 screws surrounding the D-Pad.
    • The buttons should fall out once the screws have been removed.
Conclusione
Cal Poly, Team 1-42, Maness Winter 2014 Membro di Cal Poly, Team 1-42, Maness Winter 2014
CPSU-MANESS-W14S1G42
5 Membri
16 Guide realizzate
Un commento
Thanks for the guide. The title photo shows a Lynx II, however, while all the detailed instructions are for the original Lynx (I) which is built differently.
It would be great to have a Lynx II disassembly and MOSFET Q12 replacement guide.
Siegfried Lenz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,193
