Introduzione
If your Realistic Weatheradio is not producing any sound and your battery is still functioning, then the antenna is likely faulty and needs to be replaced. This guide will show users a quick and simple process on how to replace a faulty antenna.
Cosa ti serve
To remove the back panel from the Weather radio, use your index finger and push down on the tab located on the back.
After following these steps, the Realistic Weatheradio should be able to work and function normally.
Altre 2 persone hanno completato questa guida.
