Salta al contenuto principale
Replacement of Hardware on a Crossbody bag
Cosa ti serve
  1. Replacement of Hardware on a Crossbody bag, Hardware on a Crossbody bag: passo 1, immagine 1 di 2 Replacement of Hardware on a Crossbody bag, Hardware on a Crossbody bag: passo 1, immagine 2 di 2
    • Remove the old stitching with the seam ripper blade.
    • Use the seam ripper blade carefully as it is very sharp.
  2. Replacement of Hardware on a Crossbody bag: passo 2, immagine 1 di 2 Replacement of Hardware on a Crossbody bag: passo 2, immagine 2 di 2
    • Remove the previous hardware from the strap.
  3. Replacement of Hardware on a Crossbody bag: passo 3, immagine 1 di 1
    • Measure, and ensure the new hardware fits.
    • Place the new hardware through the strap.
  4. Replacement of Hardware on a Crossbody bag: passo 4, immagine 1 di 2 Replacement of Hardware on a Crossbody bag: passo 4, immagine 2 di 2
    • Use the needle and thread to stitch the new hardware into place.
    • Using the adequate needle for the material you need is essential, as some materials may be thicker and need a larger needle.
    • Use needle and thread carefully, as the needle can be sharp.
  5. Replacement of Hardware on a Crossbody bag: passo 5, immagine 1 di 1
    • Verify the stitching is secure by hanging the crossbody bag.
Linea Traguardo
joanna
Membro da: 02/20/24
122 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 54
