Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
    • Insérer un commentaire.
Linea Traguardo
Altre 21 persone hanno completato questa guida.
ian mdx
Membro da: 30/06/2016
7.888 Reputazione
17 Guide realizzate
Am I to assume that I dont need to reapply or replace glue or adhesive strips? Is simply reheating the previous glue good enough to hold it?
Andrew Gross - Replica
You might get away with re-heating the previously used glue the first time, however you may also notice the screen lifting from the frame. I would suggest using 99% Isopropyl alcohol to remove any excess or poorly positioned glue remaining after removing the LCD and re-applying a small amount of E8000 around the edges where there is glue missing. Posting this answer very late, but only because I know people are still repairing the Note8 using similar guides because it’s how I got here.
Jack Donovan -
note8 siyah ekran bozuldu. fiyat nedir
yasin tufekci - Replica
Mine is coming up saying Note Network found after completion of the repair any ideas?
James Turner - Replica
Will the phone remain waterproof after this repair?
cj-dm - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 89
Tutti i Tempi: 22,628
