Introduzione
This technique can used to support and fix the broken plastic portions of a number of plastic toys with parts that frequently snap such as axles, spouts, legs etc.
Parti
Nessuna parte richiesta.
  1. Match up the broken plastic part and check that the pieces align.
    • Match up the broken plastic part and check that the pieces align.
    • The plastic part was hollow and had space to insert the wood support.
  2. Tools needed:
    • Tools needed:
    • - Glue (Super glue, Wood Glue or Tacky glue)
    • - A bamboo chopstick from your favorite chinese restaurant
  3. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  4. Cut the chopstick to the required size using a sharp knife.
    • Cut the chopstick to the required size using a sharp knife.
    • Some trimming and shaving may be needed depending on the plastic part and the wooden dowel with the objective of to get a tight fit.
  5. Apply a drop of glue to the ends of the wooden dowel.
    • Apply a drop of glue to the ends of the wooden dowel.
  6. Insert the wooden dowel into one part of the broken plastic part.
    • Insert the wooden dowel into one part of the broken plastic part.
  7. Insert the other end of the wooden dowel into the other end of the plastic toy. Push the ends together to get a tight and clean fit.
    • Insert the other end of the wooden dowel into the other end of the plastic toy.
    • Push the ends together to get a tight and clean fit.
Conclusione
claudius
Membro da: 12/12/2010
29 Reputazione
2 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,971
