Introduzione
Your sliding closet door should glide effortlessly on its track. Is it stuck, hard to slide, or off track? This guide will help fix that.
Strumenti
Ricambi
Nessuna parte specificata.
Remove the screw on the top right side of the closet door that is not functioning correctly. Use a Phillips head screwdriver and rotate the screw counter clockwise until it falls out. You might want to use a stepladder to do this if you can't reach easily.
Reminder Be sure to put the screws where you can find them again! I suggest using a bowl or a cup. You will need the screws again later.
Do the same to the top left side of the closet door.
Have a friend hold up closet door while you align rollers with the slots of the closet door.
Once the rollers are aligned, help your friend carefully slide the rollers back into the door.
Note Use the second picture of this step as a reference on how to slide the rollers back into the door.
