Salta al contenuto principale
Repairing Tritton Kunai Speaker Buzzing Noise
Cosa ti serve
  1. Repairing Tritton Kunai Speaker Buzzing Noise, Repairing Tritton Kunai Speaker Buzzing Noise: passo 1, immagine 1 di 2 Repairing Tritton Kunai Speaker Buzzing Noise, Repairing Tritton Kunai Speaker Buzzing Noise: passo 1, immagine 2 di 2
    • Remove the cushion of the speaker that the buzzing noise is occurring.
  2. Repairing Tritton Kunai Speaker Buzzing Noise: passo 2, immagine 1 di 3 Repairing Tritton Kunai Speaker Buzzing Noise: passo 2, immagine 2 di 3 Repairing Tritton Kunai Speaker Buzzing Noise: passo 2, immagine 3 di 3
    • Use the Philips PH00 screwdriver to unscrew the four screws located on the inner part of the rail adjustment.
  3. Repairing Tritton Kunai Speaker Buzzing Noise: passo 3, immagine 1 di 2 Repairing Tritton Kunai Speaker Buzzing Noise: passo 3, immagine 2 di 2
    • Remove the black metal bracket by unscrewing the two screws connecting it to the railing.
  4. Repairing Tritton Kunai Speaker Buzzing Noise: passo 4, immagine 1 di 2 Repairing Tritton Kunai Speaker Buzzing Noise: passo 4, immagine 2 di 2
    • Unscrew the screws in the locations shown to remove the speaker cover.
  5. Repairing Tritton Kunai Speaker Buzzing Noise: passo 5, immagine 1 di 1
    • Place the black cover to the side, near the rest of the setup.
  6. Repairing Tritton Kunai Speaker Buzzing Noise: passo 6, immagine 1 di 2 Repairing Tritton Kunai Speaker Buzzing Noise: passo 6, immagine 2 di 2
    • Observe the wire orientation: The red metal wire should be to the far left, while the green metal wire should be next to it, the skinny red rubber wire should be second to the right, and the thick red rubber wire should be to the far right. If any of the wires are out of place fasten them into their proper positions.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,181
