Salta al contenuto principale
Repairing Sony Xperia L Volume Control Button
Cosa ti serve
  1. Repairing Sony Xperia L Volume Control Button, Open the phone case: passo 1, immagine 1 di 3 Repairing Sony Xperia L Volume Control Button, Open the phone case: passo 1, immagine 2 di 3 Repairing Sony Xperia L Volume Control Button, Open the phone case: passo 1, immagine 3 di 3
    • The Xperia L model
    • Gently open the phone case.
    • The phone body, back case and the detached volume control button.
  2. Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: passo 2, immagine 1 di 2 Repairing Sony Xperia L Volume Control Button, Adjust the plastic notches using the plastic opening tools.: passo 2, immagine 2 di 2
    • Using the plastic opening tools in the iFixit kit, pull up the flattened plastic notches that will hold the volume control button in place.
    • You can see the notches on the back case and the holes in the volume control button that snap fit in them.
  3. Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: passo 3, immagine 1 di 2 Repairing Sony Xperia L Volume Control Button, Place the button and snap it to the back case using the raised notches.: passo 3, immagine 2 di 2
    • Place the volume control button back in the slot.
    • Adjust the holes on the button in a way that they snap to the raised notches on the back panel.
    • Press down the raised plastic notches using the back of the plastic opening tool from the kit.
  4. Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: passo 4, immagine 1 di 3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: passo 4, immagine 2 di 3 Repairing Sony Xperia L Volume Control Button, Snap the back case to the phone body.: passo 4, immagine 3 di 3
    • The volume control button is now attached in its slot.
    • Reassemble the phone back by snapping the back case to the phone body.
    • The volume control/zoom button is good to use!
Conclusione
Altre 3 persone hanno completato questa guida.
Ruchita
Membro da: 10/22/15
97 Reputazione
1 Guida realizzata
PIRL Gadget Garage Membro di PIRL Gadget Garage
Community
9 Membri
10 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 2,766
