Introduzione
If your machine stops working, giving you a E17 error, the manual states there is an issue with the water. This guide will help you try fixing one potential reason of this error occurring.
Parti
Nessuna parte richiesta.
  • Please follow the manual that was delivered with your machine first, as this guide will only fix one very specific cause of the E17 error and there are many others that are easier to fix. If your E17 warning started after your washing machine started 'walking' this guide might be applicable.
  • Please make sure to first check if there is any water at all, if there is no water: this manual does not apply!
  • First: Make sure you disconnect any (power) cable and take any measures needed to work safe.
  • Please note: You might void your guarantee. This manual was created after looking what a professional service engineer actually checked and fixed.
Aggiungi Commento
To check the cable that might have come loose, we need to remove the top-lid (think before you act: this may void any guarantee by Siemens!). There are two screws at the back of the machine that need to be removed to be able to move the top-lid to the back and lift it.
  • To check the cable that might have come loose, we need to remove the top-lid (think before you act: this may void any guarantee by Siemens!). There are two screws at the back of the machine that need to be removed to be able to move the top-lid to the back and lift it.
Aggiungi Commento
  • Now you can look into the machine. Don't touch! Just look if you see a black empty cable hanging loose (see middle of the photo). If so, you actually have this problem, otherwise you have a random other problem and this guide is not for you.
Aggiungi Commento
  • The black cable should be connected into the white holder in the bottom of the detector (in the top of the photo). Reconnect it.
Aggiungi Commento
  • Put the top-lid back, and your done. Please make sure the machine is stable and run a wash.
Aggiungi Commento
Linea Traguardo
Altre 3 persone hanno completato questa guida.
iAmWill
Membro da: 19/09/2014
173 Reputazione
1 Guida realizzata
Worked for me, thanks!
hpcosme - Replica
First chech if there is any water at all. Malfunction of a waterlock gives the same error and has nothing to do with your washingmachine.
aldowillebrands - Replica
Added it more explicit to the manual above. Thnx!
iAmWill -
First checked inlate pipe of filter washing machine. is clean. and then water tap of water is coming properly pressure. if all is right. and then washing machine start.
sarfarazahmad993051 - Replica
Worked for me today!!:-) then i can cancel the service man!!:-) tanx!!
Rune Amdam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 30
Ultimi 7 Giorni: 177
Ultimi 30 Giorni: 719
Tutti i Tempi: 29,146
