Salta al contenuto principale
Introduzione
How to manually advance a stuck gear train.
Parti
Nessuna parte specificata.
  1. Move film door slide on the left side of camera forward. Pull film door open.
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Locate small silver gear in top left corner of film bay.
    • Locate small silver gear in top left corner of film bay.
  3. Using a plastic opening tool, rotate gear downward until jam is cleared.
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
Conclusione
Altre 4 persone hanno completato questa guida.
Matthew Lessig
Membro da: 20/01/2010
54 Reputazione
3 Guide realizzate
Cal Poly, Team 3-18, Maness Winter 2010 Membro di Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Membri
4 Guide realizzate
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - Replica
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 20
Tutti i Tempi: 6,962
