Salta al contenuto principale
Repairing Polaroid Sun 600 LMS Gear Train
Cosa ti serve
  1. Repairing Polaroid Sun 600 LMS Gear Train, Open film door: passo 1, immagine 1 di 2 Repairing Polaroid Sun 600 LMS Gear Train, Open film door: passo 1, immagine 2 di 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Repairing Polaroid Sun 600 LMS Gear Train: passo 2, immagine 1 di 1
    • Locate small silver gear in top left corner of film bay.
  3. Repairing Polaroid Sun 600 LMS Gear Train: passo 3, immagine 1 di 1
    • Using a plastic opening tool, rotate gear downward until jam is cleared.
Conclusione
Altre 5 persone hanno completato questa guida.
Cal Poly, Team 3-18, Maness Winter 2010 Membro di Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Membri
4 Guide realizzate
3 Commenti
How do you know if the jam is cleared ? I have the same camera but the problem with mine is the shutter button. Every time I press the red and black one it won't make the noise or spit out the film unless I go one button behind. Although when I do that the photo comes out black. I think the two buttons or supposed to be together so when you press the red and black button the one behind it moves in sync. I really need help on fixing it and I'm not sure if what I said made any sense but I need help.
Tiffany - Replica
I have this very same problem…You explained it perfectly, however, I can’t figure out how to fix it. Please someone help us!
Jordan Brown -
Currently trying to fix it but after the steps it isn’t working. How do I know how many times to turn the gear?
Eleanor Murphy - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 73
Tutti i Tempi: 9,107
