Salta al contenuto principale
Repairing Oster 6344 Toaster Lever
Cosa ti serve
  1. Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: passo 1, immagine 1 di 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: passo 1, immagine 2 di 3 Repairing Oster 6344 Toaster Lever, Repairing Oster 6344 Toaster Lever: passo 1, immagine 3 di 3
    • Assure the toaster is unplugged.
  2. Repairing Oster 6344 Toaster Lever: passo 2, immagine 1 di 2 Repairing Oster 6344 Toaster Lever: passo 2, immagine 2 di 2
    • Look down into the bread slots and assure that the metal tongues are not bent or crooked.
    • If the metal tongues are bent use the pliers to straighten them.
    • Plug your toaster back in and test it to see if the lever stays down.
  3. Repairing Oster 6344 Toaster Lever: passo 5, immagine 1 di 1
    • (Optional): To clean the toaster, make sure it is unplugged, empty the crumb tray and then clean out all visible residue.
    • Note: Compressed air, wooden skewers, and slightly damp, lint free cloths are most helpful when cleaning your toaster.
    • Be sure that the toaster is completely dry from cleaning before you reassemble it.
Conclusione
Daniel
Membro da: 07/13/13
109 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 21
Tutti i Tempi: 1,648
