Salta al contenuto principale
Repairing Nokia 6500 Slide LCD
Cosa ti serve
  1. Repairing Nokia 6500 Slide LCD, LCD: passo 1, immagine 1 di 3 Repairing Nokia 6500 Slide LCD, LCD: passo 1, immagine 2 di 3 Repairing Nokia 6500 Slide LCD, LCD: passo 1, immagine 3 di 3
    • Press the eject button to open battery enclosure. Remove battery, sim card and micro sd card.
  2. Repairing Nokia 6500 Slide LCD: passo 2, immagine 1 di 1
    • Remove four screws using torx 5 screwdriver.
  3. Repairing Nokia 6500 Slide LCD: passo 3, immagine 1 di 3 Repairing Nokia 6500 Slide LCD: passo 3, immagine 2 di 3 Repairing Nokia 6500 Slide LCD: passo 3, immagine 3 di 3
    • Pry each side evenly around its edges. The phone should start to split into two halves.
  4. Repairing Nokia 6500 Slide LCD: passo 4, immagine 1 di 2 Repairing Nokia 6500 Slide LCD: passo 4, immagine 2 di 2
    • The top and bottom half of the phone is still connected by two ribbon connectors each side. Use a thin plastic like a credit card to carefully disconnect it.
  5. Repairing Nokia 6500 Slide LCD: passo 5, immagine 1 di 1
    • Make sure all components stay on each side (see picture).
  6. Repairing Nokia 6500 Slide LCD: passo 6, immagine 1 di 2 Repairing Nokia 6500 Slide LCD: passo 6, immagine 2 di 2
    • Pull the black part away from the rest of the phone in the direction shown by the white arrows follows by the blue.
    • This way you can accessing the two screws at the bottom of the phone. Remove four srews using torx 5 screwdriver.
  7. Repairing Nokia 6500 Slide LCD: passo 7, immagine 1 di 2 Repairing Nokia 6500 Slide LCD: passo 7, immagine 2 di 2
    • Carefully pry out the lcd cover.
    • Make sure the board connector pass the cover by angle.
  8. Repairing Nokia 6500 Slide LCD: passo 8, immagine 1 di 3 Repairing Nokia 6500 Slide LCD: passo 8, immagine 2 di 3 Repairing Nokia 6500 Slide LCD: passo 8, immagine 3 di 3
    • Disconnect the LCD connector.
    • Carefully peel the ribbon away from the back of the screen. It's held in place with double sided tape.
    • The LCD screen will now be loose and can be removed and replace with the new one.
Conclusione
dwi
Membro da: 07/02/13
163 Reputazione
1 Guida realizzata
2Commenti sulla guida
Great - have screen in. Now, have you ever replaced the port / jack for the charger? Mine will not accept the prong all of a sudden
Brenda Kent - Replica
Got new charger port in 2017, now the battery goes - tried several batteries - and tried them in other phones and are fine - thinking something shorting or draining it in the phone?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 37
Tutti i Tempi: 4,678
