Salta al contenuto principale
Repairing Nintendo 64 Controller Joystick Replacement
Cosa ti serve
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: passo 1, immagine 1 di 3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: passo 1, immagine 2 di 3 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: passo 1, immagine 3 di 3
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: passo 2, immagine 1 di 3 Repairing Nintendo 64 Controller Joystick Replacement: passo 2, immagine 2 di 3 Repairing Nintendo 64 Controller Joystick Replacement: passo 2, immagine 3 di 3
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: passo 3, immagine 1 di 3 Repairing Nintendo 64 Controller Joystick Replacement: passo 3, immagine 2 di 3 Repairing Nintendo 64 Controller Joystick Replacement: passo 3, immagine 3 di 3
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
Conclusione
Test out your controller! It should be feeling like new.
Altre 33 persone hanno completato questa guida.
Zillatron
Membro da: 08/28/12
1.511 Reputazione
1 Guida realizzata
2 Commenti
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - Replica
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 39
Ultimi 30 Giorni: 177
Tutti i Tempi: 44,288
