Salta al contenuto principale
Repairing Mitsubishi WS-65511 Blinking green light fuse replacement
Cosa ti serve
  1. Repairing Mitsubishi WS-65511 Blinking green light fuse replacement, Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 1, immagine 1 di 2 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement, Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 1, immagine 2 di 2
    • Unplug the set. disconnect the coax cable and any other device plugged into the TV.
    • Remove the back panel
    • The antenna coax cable as well as other device connect directly to the DM module which is enclosed in a metal case.
  2. Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 2, immagine 1 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 2, immagine 2 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 2, immagine 3 di 3
    • Disconnect the wiring coming off the DM board to the main chassis. On this TV there were four separate wiring harnesses: DA,VA,DB and PF. These markings are not of importance to this repair. But they all are clearly marked on the connectors as well as the logic board they connect to. This will help to identify their proper position for the re-assembly.
    • Undo the two screws that hold the plastic cover to the DM board.
  3. Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 3, immagine 1 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 3, immagine 2 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 3, immagine 3 di 3
    • To the bottom right is a screw that connects a ground strap and holds the board to the chassis, undo that.
    • With all the connector disconnected, the ground strap removed, pull the DM board carefully from the chassis. Some models have a small tab stop that you must push down to release the board.
  4. Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 4, immagine 1 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 4, immagine 2 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 4, immagine 3 di 3
    • Remove the wiring attached to it (PD,PE,PF). These are simple connector and can just pulled of. These markings are not of importance to this repair. But they all are clearly marked on the connectors as well as the logic board they connect to. This will help to identify their proper position for the re-assembly.
    • Remove the four screws holding the board on.
    • This board has 7 1000uf 16Volt capacitors. These are the ones that have a tendency of failing. Inspect those for bulging tops as well as leakage. In this case, one capacitors was sligthly bulged.
  5. Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 5, immagine 1 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 5, immagine 2 di 3 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 5, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Desoldering Pump
    $3.99
    Compra
    • Unsolder all the capacitors and remove them. In this repair a 30watt soldering iron and solder sucker was used. The solder sucker can be substituted with soldering wick.
    • Solder all the capacitors in their respective places. On the logic board, where the capacitors are located, is an outline of a circle with one part of the circle being heavier. It corresponds with the negative lead of the condenser.
    • Once all the capacitors are replaced, double check the board to make sure everything is properly mounted.
  6. Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 6, immagine 1 di 2 Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 6, immagine 2 di 2
    • While the board and the DM power module are accessible check the SMD fuses for continuity. There are two on the daughter board. In this case, the fuses had continuity and were functioning.
    • The main PCB has two fuses on the underside. In order to get to it, one will have to disassemble the module further. This was skipped in this repair.
  7. Repairing Mitsubishi WS-65511 Blinking green light fuse replacement: passo 7, immagine 1 di 1
    • With the repair completed, everything should be double checked for proper soldering and proper polarity. The unit was re-assembled in reverse order. Reconnect all the wiring connectors. Double check for proper positioning and that all the connectors are properly seated.
    • The TV was plugged in and after a minute of the green light flashing,.....IT WORKED. Total cost of repair was $13 dollars for the UVK1C102MPD capacitors, which includes $7 for shipping.
Conclusione
Altre 19 persone hanno completato questa guida.
oldturkey03
Membro da: 09/29/10
782.480 Reputazione
119 Guide realizzate
Global Fixers Membro di Global Fixers
Community
33 Membri
544 Guide realizzate
23 Commenti
I want to thank oldturkey 03! My ws-65511 had a blinking green light after a lightening storm, & wouldn't come on. We looked up this guide that you put online. We followed it exactly. I ordered the exact parts you listed, for $14 from Mouser Electronics. I got the capacitors in a couple of days. My wonderful Dad came over and completed the repair according to your instructions. We plugged it in, and it works like new. Even better than before, because while we had the back off, I cleaned the lenses, which made a huge improvement. I can't thank you enough for unselfishly spending your time to put this online, to help other people. Your expertise saved me over $1000, by not having to buy a new TV. That is worth a huge and heartfelt THANK YOU! THANK YOU to my Dad too, since he actually did the repair. :) I will make this note for anyone else that wants to try it. Our capacitors did not look bubbled, or blown, and weren't leaking. We replaced them anyway, and it worked beautifully. HAPPY DAY!!
Lori - Replica
Great instructions. It cost me $20 to fix, which was the cost of the fuses plus freight. Thank you very much.
Bruce - Replica
Worked for me too!!!
Same problem, followed instructions and "WOW" watching my HD tv again!!
Thanks a million, Digikey parts under $10--I owe You!!!
Elvis 3/23/14
Elvis - Replica
I had the same issue and replaced the capacitors and it worked for about 3 hours and backed to flashing any ideas ?
Jeff - Replica
Well it worker for us, thank you, thank you thnak you. SAved us a whole bunch of cash and I'm not an electronics person. I bought the capacitors, sodering iron, all for about $20 with shipping. Thanks again oldturkey03!
kevin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 15
Tutti i Tempi: 85,674
