Salta al contenuto principale
Repairing Minolta Dimage Xt Lens Cover
Cosa ti serve
  1. Repairing Minolta Dimage Xt Lens Cover, Casing: passo 1, immagine 1 di 3 Repairing Minolta Dimage Xt Lens Cover, Casing: passo 1, immagine 2 di 3 Repairing Minolta Dimage Xt Lens Cover, Casing: passo 1, immagine 3 di 3
    • Locate and remove the silver screws on each side of the camera.
    • Use the Phillips #00 Screwdriver to unscrew all 2.0mm (4 instances) and 4.0mm (2 instances) screws.
  2. Repairing Minolta Dimage Xt Lens Cover: passo 2, immagine 1 di 3 Repairing Minolta Dimage Xt Lens Cover: passo 2, immagine 2 di 3 Repairing Minolta Dimage Xt Lens Cover: passo 2, immagine 3 di 3
    • Then, carefully pry apart the front and back outer casing away from the internal components.
    • Be aware of the ribbon wire that will disconnect when the casing is detached.
  3. Repairing Minolta Dimage Xt Lens Cover, Lens Cover: passo 3, immagine 1 di 1
    • Place the internal electronics face-up. Look at the side with the flash turned towards you.
    • The lens cover is a small sheet of metal that rests directly infront of the lens when the camera is turned off.
    • Check to see if the spring action arm (what the yellow arrow is pointing to) is attached to the lens cover with the small knob in the corner (circled in yellow).
  4. Repairing Minolta Dimage Xt Lens Cover: passo 4, immagine 1 di 1
    • If the arm is not attached (as shown in the previous), use tweezers to place the arm over the knob on the lens cover.
    • Inside the yellow circle, the arm is in the correct position.
Conclusione
Reassemble the casing by reversing steps 1 and 2.
Megan Milam
Membro da: 03/11/13
28 Reputazione
5 Guide realizzate
Clemson, Team 12-4, Benson Spring 2013 Membro di Clemson, Team 12-4, Benson Spring 2013
CLEM-BENSON-S13S12G4
3 Membri
14 Guide realizzate
Un commento
In Bild 3 ist der gelbe Kreis falsch gesetzt: der kleine Knopf ist unten links an der Blende, wie in Bild 4 positioniert. hr
Hubert Rieping - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 947
