Introduzione
Printer will present error stating the toner cartridges are not installed when toner cartridges ARE installed. This guide will walk you through repairing and replacing the toner cartridge detection sensor.
Open top lid by pulling up on gray handle and lifting the cover open.
Pull down front cover by pulling horizontally, away from the printer, on the center of the cover.
Lift the toner handle away from the toner until you hear a "pop" and feel the cartridge disengage from the cartridge holder.
Lift the up by the handle; it will pivot around the top edge of the cartridge holder. Continue lifting until toner stops pivoting.
You can now lift the toner straight up, out of the cartridge holder.
Insert a thin rod into the "barrel" shaped hold on the right side of the printer. This will disengage the cartridge holder lock. You will need to press and hold to keep the lock disengaged.
Press down on the empty cartridge slot. The carousel will begin to rotate.
Rotate the carousel until the cartridge pivot tabs line up the the alignment opening.
Repeat steps 2 and 3 until all toner cartridges are removed.
Altre 2 persone hanno completato questa guida.
2 Commenti
Dear HoyeBoye !
I did everything just like in the description, but my printer does not detect any of the toners. Do you have any idea what should I do?
Thank in advance,
Viktor
I’m afraid I don’t have any further suggestions. If you are trying to re-fill an old toner cartridge, the cartridges have an embedded chip that prevents re-use.
HoyeBoye -
