Salta al contenuto principale
Repairing HP OfficeJet 3833 Paper Jam
Cosa ti serve
  1. Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: passo 1, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam, Repairing HP OfficeJet 3833 Paper Jam: passo 1, immagine 2 di 2
    • Remove all paper from the printer.
  2. Repairing HP OfficeJet 3833 Paper Jam: passo 2, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam: passo 2, immagine 2 di 2
    • Check the input tray, located in the back of the printer, for any paper remains and remove them.
  3. Repairing HP OfficeJet 3833 Paper Jam: passo 3, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam: passo 3, immagine 2 di 2
    • Check the input tray for any foreign objects.
    • You may need to hold down the input tray and shine a flashlight inside to have a better look.
    • Long tweezers are recommended to remove objects such as thumbnails and tacks.
  4. Repairing HP OfficeJet 3833 Paper Jam: passo 4, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam: passo 4, immagine 2 di 2
    • Check the output tray, located in the front of the printer, for paper remains and remove them.
  5. Repairing HP OfficeJet 3833 Paper Jam: passo 5, immagine 1 di 3 Repairing HP OfficeJet 3833 Paper Jam: passo 5, immagine 2 di 3 Repairing HP OfficeJet 3833 Paper Jam: passo 5, immagine 3 di 3
    • Shut down the printer.
    • Hold down the power button until a message appears.
    • Select the Shut Down option.
    • A message will appear and the printer will turn off.
  6. Repairing HP OfficeJet 3833 Paper Jam: passo 6, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam: passo 6, immagine 2 di 2
    • Unplug the printer power cable from the wall outlet.
    • Remove the power cable from the back of the printer.
  7. Repairing HP OfficeJet 3833 Paper Jam: passo 7, immagine 1 di 3 Repairing HP OfficeJet 3833 Paper Jam: passo 7, immagine 2 di 3 Repairing HP OfficeJet 3833 Paper Jam: passo 7, immagine 3 di 3
    • Pull back on the front sides of the printer to remove the front panel.
    • Then pull the handle inside to remove the ink cartridge panel.
  8. Repairing HP OfficeJet 3833 Paper Jam: passo 8, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam: passo 8, immagine 2 di 2
    • Slide the ink cartridge to the side.
    • This step must be done carefully to prevent damage to the printer.
  9. Repairing HP OfficeJet 3833 Paper Jam: passo 9, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam: passo 9, immagine 2 di 2
    • Search for and remove any debris.
  10. Repairing HP OfficeJet 3833 Paper Jam: passo 10, immagine 1 di 1
    • Put the printer on its side.
    • You may need to open the top half and lay it down to prevent the printer from falling.
  11. Repairing HP OfficeJet 3833 Paper Jam: passo 11, immagine 1 di 2 Repairing HP OfficeJet 3833 Paper Jam: passo 11, immagine 2 di 2
    • Locate the cleanout door on the bottom half of the printer.
    • Open the cleanout door to remove unwanted debris.
Linea Traguardo
Ivory S. Mayorga
Membro da: 09/16/20
193 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 71
Tutti i Tempi: 2,822
