Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Stalled printer for error 0xF2 or 0xF3
The error compare when there are some problem with encoder with roller to feed paper.
Parti
Nessuna parte specificata.
  1. Remove the paper tray Remove the paper cassette Remove Ink tanks
    • Remove the paper tray
    • Remove the paper cassette
    • Remove Ink tanks
  2. Remove opening covers Remove opening covers
    • Remove opening covers
  3. Remove Rear component
    • Remove Rear component
  4. Dismount Ink lever
    • Dismount Ink lever
  5. Remove Front panel screws Remove Front panel screws
    • Remove Front panel screws
  6. Dismount LCD Panel Dismount LCD Panel
    • Dismount LCD Panel
  7. Remove front panel Remove front panel Remove front panel
    • Remove front panel
  8. Remove back panel screws Remove back panel screws Remove back panel screws
    • Remove back panel screws
  9. Remove last back panel screw (hidden behind the LCD display) Remove last back panel screw (hidden behind the LCD display)
    • Remove last back panel screw (hidden behind the LCD display)
  10. Remove back ethernet panel
    • Remove back ethernet panel
  11. Remove main back panel, being careful not to damage the LCD display Remove main back panel, being careful not to damage the LCD display Remove main back panel, being careful not to damage the LCD display
    • Remove main back panel, being careful not to damage the LCD display
  12. Clean left encoder very gently with a dry tissue or a soft brush Clean left encoder very gently with a dry tissue or a soft brush
    • Clean left encoder very gently with a dry tissue or a soft brush
  13. Clean right encoder very gently with a dry tissue or a soft brush. Clean right encoder very gently with a dry tissue or a soft brush. Clean right encoder very gently with a dry tissue or a soft brush.
    • Clean right encoder very gently with a dry tissue or a soft brush.
  14. If you want to test the printer you need to insert paper, and cover 2 switches with tape. If you want to test the printer you need to insert paper, and cover 2 switches with tape.
    • If you want to test the printer you need to insert paper, and cover 2 switches with tape.
  15. Reassemble the printer (remove the tape first if you have used it) following these instructions in reverse.
    • Reassemble the printer (remove the tape first if you have used it) following these instructions in reverse.
Conclusione
Altre 15 persone hanno completato questa guida.
delete
Membro da: 15/11/2012
517 Reputazione
1 Guida realizzata
It's works, thanks
Thom - Replica
Perfect. I used this guide to disassemble my printer.
I had 0xF1 and/or 0xF4. The reason was some paper stuck between the gears of the paper feed (in this guide step 12).
I hope this hint will help others. I didn't find any info about these error code online.
DumahBrazorf - Replica
Error descriptions I found here - http://www.fatalerrors.info/
John Smith -
Thank you very much ! This is a very useful and beautifully documented guide. Best wishes and greetings to the kind author of this guide from Bratislava, Slovakia.
George Pekarovic
George - Replica
muito obrigado pela ajuda
Filipe Rocha - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 134
Tutti i Tempi: 56,026
