Salta al contenuto principale
Repairing Display
Cosa ti serve
  1. Repairing Display, Display: passo 1, immagine 1 di 1
    • Remove the 6 outer screws on the underside of the laptop.
    • Open the battery compartment and remove the 7 visible screws.
    • Pry the corners of the bezel at the base of the keyboard, pushing up until it loosens.
    • Carefully remove the ribbon connections of the keyboard, power button, and wifi button.
    • Disconnect and re-connect the white monitor ribbon located on the left side to make sure it sits firmly in the connection.
    • Reassemble the laptop by following these steps in reverse.
    • The monitor should work when powered on again.
Conclusione
Altre 9 persone hanno completato questa guida.
duncan
Membro da: 06/28/12
238 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 19
Tutti i Tempi: 12,133
