Salta al contenuto principale
Repairing Canon PowerShot Lens Error E-18
Cosa ti serve
  1. Repairing Canon PowerShot Lens Error E-18, Repairing Canon PowerShot Lens Error E-18: passo 1, immagine 1 di 1
    • Place camera lens facing upwards on the table.
    • Press and hold down the power button.
    • Simultaneously press down the shutter button.
  2. Repairing Canon PowerShot Lens Error E-18: passo 2, immagine 1 di 1
    • Replace the batteries in the camera.
    • To open the battery cover slide the black lever on the underside of the camera and pull the cover toward the front.
    • Remove the old batteries from the camera and wait a few moments.
    • Put in a fresh set of batteries.
    • Close battery slide and power camera back on.
  3. Repairing Canon PowerShot Lens Error E-18: passo 3, immagine 1 di 1
    • Put blow dryer in the "no heat" setting prior to plugging it in.
    • Plug in and turn the blow dryer on.
    • Blow air in the gaps between the lens.
Conclusione
In conclusion, using this guide to fix the E-18 on the lens of the Canon PowerShot A80,will allow the camera to capture photos once again. To reassemble your device, follow these instructions in reverse order.
Altre 2 persone hanno completato questa guida.
Tim
Membro da: 01/06/11
172 Reputazione
1 Guida realizzata
Cal Poly, Team 7-31, Regan Winter 2011 Membro di Cal Poly, Team 7-31, Regan Winter 2011
CPSU-REGAN-W11S7G31
6 Membri
12 Guide realizzate
Un commento
merci! mon appareil fonctionne à nouveau
nadia.labadi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 123
Tutti i Tempi: 6,357
