Salta al contenuto principale
Repairing Bose On-Ear headphones Shorted Right earphone
Cosa ti serve
  1. Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: passo 1, immagine 1 di 2 Repairing Bose On-Ear headphones Shorted Right earphone, Repairing Bose On-Ear headphones Shorted Right earphone: passo 1, immagine 2 di 2
    • To repair a short in the wires, the head band has two screws, just above the headphones cups.
  2. Repairing Bose On-Ear headphones Shorted Right earphone: passo 2, immagine 1 di 2 Repairing Bose On-Ear headphones Shorted Right earphone: passo 2, immagine 2 di 2
    • After removing the two small screws, try closing the headband to it's shortest position. The outer panel will pop out toward the bottom edge.
    • You can then slide the panel out from under the collar. The collar may slide out of place while working, but can easily be slid back during re-assembly.
  3. Repairing Bose On-Ear headphones Shorted Right earphone: passo 3, immagine 1 di 2 Repairing Bose On-Ear headphones Shorted Right earphone: passo 3, immagine 2 di 2
    • After inspecting the wire inside, you may notice cracks in the corners were the wires bend when the headphones are folded. I cut a thin strip of electrical tape to use as reinforcement.
    • After sliding the collar up, you can extend the wire, giving you better access for wrapping or replacing.
Conclusione
Altre 5 persone hanno completato questa guida.
Designer Dan
Membro da: 11/03/12
274 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 26
Tutti i Tempi: 5,133
