Salta al contenuto principale
  1. To repair a short in the wires, the head band has two screws, just above the headphones cups. To repair a short in the wires, the head band has two screws, just above the headphones cups.
    • To repair a short in the wires, the head band has two screws, just above the headphones cups.
  2. Kit di riparazione per Android
    A new screen or battery is one kit away.
    Acquista ora
    Acquista ora
  3. After removing the two small screws, try closing the headband to it's shortest position. The outer panel will pop out toward the bottom edge. You can then slide the panel out from under the collar. The collar may slide out of place while working, but can easily be slid back during re-assembly.
    • After removing the two small screws, try closing the headband to it's shortest position. The outer panel will pop out toward the bottom edge.
    • You can then slide the panel out from under the collar. The collar may slide out of place while working, but can easily be slid back during re-assembly.
  4. After inspecting the wire inside, you may notice cracks in the corners were the wires bend when the headphones are folded. I cut  a thin strip of electrical tape to use as reinforcement. After sliding the collar up, you can extend the wire, giving you better access for wrapping or replacing.
    • After inspecting the wire inside, you may notice cracks in the corners were the wires bend when the headphones are folded. I cut a thin strip of electrical tape to use as reinforcement.
    • After sliding the collar up, you can extend the wire, giving you better access for wrapping or replacing.
Conclusione
Altre 5 persone hanno completato questa guida.
Designer Dan
Membro da: 03/11/2012
274 Reputazione
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 25
Tutti i Tempi: 3,617
