Salta al contenuto principale
Repairing Black Display on an Asus Transformer TF101
Cosa ti serve
  1. Repairing Black Display on an Asus Transformer TF101, Bezel: passo 1, immagine 1 di 2 Repairing Black Display on an Asus Transformer TF101, Bezel: passo 1, immagine 2 di 2
    • The first step is to remove two Small Torx Screws on the bottom. I don't know the size as I happened to have an unmarked Torx screwdriver nearby that happened to fit.
  2. Repairing Black Display on an Asus Transformer TF101: passo 2, immagine 1 di 2 Repairing Black Display on an Asus Transformer TF101: passo 2, immagine 2 di 2
    • I used a metal opening tool to spearate the bezel from the front of the unit. Once I had it separated in one area it was relatively easy to spread it using my fingertip. I then worked around the bezel until it popped off.
  3. Repairing Black Display on an Asus Transformer TF101: passo 3, immagine 1 di 1
    • There are four screws to remove behind the bezel. I never got a good picture of the screws but two are indicated here and the other two are in a similar location but just out of the picture.
Conclusione
Altre 14 persone hanno completato questa guida.
Rene Jeddore
Membro da: 10/23/12
1.360 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 8,831
