Salta al contenuto principale
Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons
Cosa ti serve
  1. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons, Opening the Device: passo 1, immagine 1 di 1
    • Flip device upside down and remove the 4 foam pads at each corner.
    • Remove the 4 screws using a Philips Screwdriver.
    • Gently lift the case off of the body and set down in a safe place.
    • Unscrew Circuit board attached to the top of the case with the one screw in the center. Be careful not to strip the screw/break the circuit board.
  2. Repairing AcuRite Intelli-Time Alarm Clock Unresponsive Buttons: passo 5, immagine 1 di 1
    • Make sure all of the buttons are move-able.
    • Press buttons on circuit board while listening for a click.
    • If everything works on the inside, that might mean you need a new circuit board.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 976
