Salta al contenuto principale
Repairing Acer Iconia B1-A71 Touch Screen Digitizer
Cosa ti serve
Panoramica Video
  1. Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: passo 1, immagine 1 di 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: passo 1, immagine 2 di 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer, Repairing Acer Iconia B1-A71 Touch Screen Digitizer: passo 1, immagine 3 di 3
    • Because I can't switch-off the tablet, I'm using the reset button to do this.
    • Now, remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Repairing Acer Iconia B1-A71 Touch Screen Digitizer: passo 2, immagine 1 di 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer: passo 2, immagine 2 di 3 Repairing Acer Iconia B1-A71 Touch Screen Digitizer: passo 2, immagine 3 di 3
Conclusione
Altre 15 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.278 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.528 Guide realizzate
14 Commenti
Thanks.. it worked for my tab... Great...
pandawa - Replica
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
omy - Replica
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
Andri Sagita - Replica
Thanks for the info. I fixed my tablet before by using the steps. But, I had the same problem again. I tried to fix it again but it's not wrking. So how to fix the problem with Android OS or hardware problem? Cheers.
rinayaya - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 14
Tutti i Tempi: 39,307
