Introduzione
Very often problem with this model. In 60% it can be resolved only with reconnecting the Touchscreen flex / ribbon cable.
If this solution not helped you then you must to change your Touchscreen.
Cosa ti serve
Panoramica Video
Because I can't switch-off the tablet, I'm using the reset button to do this.
Now, remove the back cover.
Altre 15 persone hanno completato questa guida.
14 Commenti
s'il vous plait vous pouvez m'aider j'ai un problème avec mon Acer B1. problème de démarrage qu'on j'allume il y'a juste Acer qui s'affiche j'ai essayer d'aller en mode recovery (SD IMAGE UPDATE MODE) mais une fois que je clique dessus ça se bloque s'il vous plait besoin de votre aide
If you have a memory card inside, remove it. If you have same problem again, you have a problem with Android OS or a hardware problem.
ZFix -
Great i thought i cannot use my acer anymore, but know its worked thx for the solutions.
