Salta al contenuto principale
Repair Broken LAN Socket "Click Retainer" RJ45 socket
Cosa ti serve
  1. Repair Broken LAN Socket "Click Retainer" RJ45 socket, Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 1, immagine 1 di 3 Repair Broken LAN Socket "Click Retainer" RJ45 socket, Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 1, immagine 2 di 3 Repair Broken LAN Socket "Click Retainer" RJ45 socket, Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 1, immagine 3 di 3
    • I purchased an "RJ45 Coupler" (Brand: Huakan) on Amazon. At the time of repair 6 couplers were sold for $6.99 ... now they are $9.99 (USA). These couplers have a thin stainless-steel frame on each side where the LAN cable "clicks" into the coupler.
1- Using a hacksaw blade, carefully cut lengthwise through the black ABS plastic covering. Use fine needle-nose pliers to peel-off the outer plastic layer. Use same pliers, to break/peel off the green rectangular circuit board.
  2. Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 2, immagine 1 di 1
    • 2- Clip the little stainless steel "nubs" from the flat sides (2-sides to each coupler, 4 total) ... also clip the black plastic "nubs" from the sides of the stainless-steel face frames. Gently push off the stainless steel face frames from the body of the RJ45 socket (2 of them).
  3. Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 3, immagine 1 di 3 Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 3, immagine 2 di 3 Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 3, immagine 3 di 3
    • After separating the stainless-steel face-frames from the RJ45 Coupler, then note the red-arrow designated "prongs" that may be adjusted to give the best "fit" over the broken RJ45 socket. Adjust as needed to provide a deep-seated firm fit.
    • Clean stainless-steel frames with isopropyl (rubbing) alcohol, also swab the edge of the broken RJ45 socket. The new frame will cover green & amber LED lights, the lights are still partly visible when lighted or when flashing.
  4. Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 5, immagine 1 di 2 Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 5, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    • 5- Slide the stainless-steel Frame over the existing RJ45 socket. The stainless-steel face frame has 2-prongs which can be made "snug" with tweezers (or similar) to provide a good fit over the edge of the existing (broken) RJ45 socket. TEST THE FIT ... adjust as needed, the stainless-steel prongs may need slight adjustment.
    • 5- I used "E6000" Industrial Glue/Adhesive (any hardware store). This makes a permanent bond . IMPORTANT: place only a very tiny amount of glue (pin-head) onto the stainless-steel face frame 'sides' (NOT the "click retainer" side) ... CAREFULLY fix the face frame in EXACTLY the alignment so the 'CLICK RETAINER' ALIGNs THE SAME AS ON THE SOCKET.
    • 6- SNUG the new stainless-steel face frame down to firmly/tightly SEAT IT to it's maximum tightness over the existing RJ45 Socket. NOTE: I pre-tested the connection by holding the stainless-steel frame in place with a small screwdriver, then plugging in the LAN cable and checking to make sure the connection was working (lighting up).
  5. Repair Broken LAN Socket "Click Retainer" RJ45 socket: passo 8, immagine 1 di 1
    • 8- IF ALL IS WORKING ... PLACE A BIT OF 'DUCT-TAPE' in-place onto the RJ45 socket and snug the frame down as deeply as it will go. WAIT 24 HRS for full cure. NOTE: be VERY careful when placing the pin-head bits of adhesive,DO NOT spill or get adhesive onto the interior of the RJ45 socket connectors, for obvious reasons ;-).
Conclusione
Altre 2 persone hanno completato questa guida.
2Commenti sulla guida
Thanks for the tip! I just repaired a Yaesu FT-891 socket that would have been a nightmare to de-solder and install a new jack. This should be just fine. Thanks again!
JKDEngineer - Replica
I have to say, this is IMHO simply a stroke of genius and at the same time so weird nobody has thought of this fix before. There must be tons of idiots like me with a busted plastic socket on a device from a cable that got yanked out by accident. I just ordered a few of these couplers to salvage the faceplate. Thanks a lot for sharing!
Wim Meert - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 94
Tutti i Tempi: 786
