Salta al contenuto principale
Remplacement des piles du clavier sans fil d'Apple
Cosa ti serve
  1. Remplacement des piles du clavier sans fil d'Apple, Piles: passo 1, immagine 1 di 1
    • Utilisez une pièce de monnaie pour enlever le couvercle du compartiment où se trouvent les piles.
  2. Remplacement des piles du clavier sans fil d'Apple: passo 2, immagine 1 di 2 Remplacement des piles du clavier sans fil d'Apple: passo 2, immagine 2 di 2
    • Faites glisser les deux piles AA du compartiment. Vérifiez que les bornes positives et négatives soient dans le bon sens.
Conclusione
Pour réassembler votre appareil, suivez les instructions dans le sens inverse.
Altre 35 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
en fr
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
rab777hp
Membro da: 11/17/09
20.333 Reputazione
3 Guide realizzate
OPEN Membro di OPEN
Community
82 Membri
25 Guide realizzate
5 Commenti
This works great - as long as the batteries inside did not leak and create a permanent seal for the cap. I managed to get the keyboard working again by removing the batteries through the electronics compartment (remove grey center cover, slide electronics out). It did take some effort (including driving a screw into the stuck battery and yanking it out with pliers) to remove the stuck batteries and all the remains of the leakage, but I ended up with a working keyboard. Only thing is that I need to use the 'backdoor' every time my batteries need replacing, since the battery cover is permanently sealed...
Otto - Replica
Also have a perma sealed battery cover. Poured vinegar in from middle and let soak over night. Wanna drill into coin slot to try and remove cover but need to get batteries out first. Can I just remove the one screw from logic board and disconnect ribbon cable, to have it slide out the power button end? How careful w cable? Looks like it has 2 tiny clips, do these need to be addressed or can I just pry it off?
William Shouse -
Warm the area where battery screw cover is in a stream of hot water from the faucet. Be careful not to get water into the keyboard or keys. The warmth will sometimes expand the aluminum enough to loosen the screw cover. Worked for mine.
Greg M - Replica
Thanks!
worked well. Had to push old battery out from electronics cover area. Keyboard working again :)
tankapoet - Replica
It’s possible, but how can I get it? I am in somali country please help me
saalix49 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 11
Ultimi 7 Giorni: 96
Ultimi 30 Giorni: 491
Tutti i Tempi: 98,125
