Introduzione
Remplacez les gâchettes de votre Nintendo DS Lite et retournez dans la course !
Cosa ti serve
Dévissez la vis cruciforme qui maintient le cache de la batterie fixé sur la console.
Soulevez le cache de la batterie avec un spudger ou votre ongle, et retirez-le de la console.
Faites levier avec la pointe d'une spatule (spudger) pour extraire les deux patins en caoutchouc de la DS Lite.
Insérez le bout plat d'une spatule entre les parties inférieure et supérieure de la coque de la DS Lite.
Faites délicatement glisser la spatule le long du bord droit de la DS Lite pour créer une ouverture.
Continuez à faire glisser la spatule le long de l'arrière de la DS Lite jusqu'à ce que les parties inférieure et supérieure se séparent.
Pour ré-assembler votre appareil, suivez ces instructions dans l'ordre inverse.
Altre 34 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
6 Commenti
Thank you this helped a lot I can finnaly play Zelda and Mario Cart now
Hi! I am attempting a trigger repair, but it seems the console was opened and worked on before I got my hands on it, and the switch for the trigger snapped off the board. I taped it to the board to test, and it still works. Is my best bet soldering the switch back to the motherboard? Or could I get away with superglue? (I've never soldered before, and this looks delicate)
I would definitely solder it, usually, these triggers are the ones that get the most stress and dirt around them so superglue might not last that much. If you have a problem with the trigger still. You might want to check the video I uploaded, it is in Spanish, though. https://youtu.be/7GRzZh9ZdNM
